Originally Posted by
cathurga
Five flights this weekend, didn’t miss a beat! I was thinking that the carb would need to be richened up a bit as the ambient temps have dropped a lot since last flights, but it ran perfectly, so didn’t change anything. They use such a little fuel it’s ridiculous. 3 x 7 minutes flying and it used 250ml...half a tank. It could get 30mins if flying in a tank, with ease.
all good in FG60 world over here....
the engine Ines will probably do another weekend of flying and then it will go through some maintenance. I want to open one cylinder up and check the carbon levels, and clean
cathurga , Good to hear your 60 is running great, How many flights before you do maintenance? I was thinking about every gallon or if I hear something with the motor.
