Originally Posted by
afv aficionado
Armortek Chieftain 1/6th cupola with acrylic block periscopes - WIP - Builder Youngjae Bae, South Korea
Mylar sheet cut to fit periscopes
Mylar sheet fitted to turret scopes - note reflections
Source material for mylar sheet - mini chocolate bar multi pack - free from chocolate contamination
Hi Woz
Are you planning on doing a 3D print print upgrade for the cupola?
If so, would you consider doing one with empty periscopes - that would allow insertion of acrylic block scopes & mylar film (mirror)?
Mk 10 cupola - is that the one with periscopes angled downward at 15 degrees to prevent reflections? Pt 11 in Stephen Whites Mk 5 guide has a bit about it.
You might want to consider doing the latter NBC pack too - point 9 in the guide refers. Guide -
Chieftain Mk 5 Guide - Armortek -
Mal
Hi
I'm going to print them in resin with clear resin periscopes.
