Originally Posted by
Zeeb
I don't know of anyone installing a pitot tube airspeed indicator, most are using radios with GPS which will give you ground speed readouts which is usually good enough.
All of my jets have airspeed. It is easy install and it makes consistent approaches much easier. You are right that if you want to just get a rough speed for wow factor GPS is fine and being that my airspeed is not callobrated in any way gps may be about as accurate but I don't care for my use. I use the airspeed for approach mostly. I do stall tests then set my approach speed accordingly. Don't care if my actual speed is 30, 40, 50, etc. Just that I am flying the same speed on each approach.
