Originally Posted by
Viper1GJ
Carston,
I want to use one of my CTUs in a Freewing F-22 EDF foamy turbine conversion. It will be useful nose weight.
Can you tell me if the CTU is powered from the ECU or from the receiver. I have to use a 5 volt BEC to power the receiver, servos, and retracts, but need to power the Kingtech ECU with at least 6v. The CTU connects between the ECU and receiver, so I want to know where the power for the CTU is drawn from. Using Jeti REX12A, DS-24, and K-45G3 ECU.
This would be a good platform to play with Dave's auto throttle also.
Gary
Gary,
The CTU is powered from the receiver. The ECU connection is "data only"
Regards,
C
Arsten
