Originally Posted by
cathurga
Hey all,
I was given one of these engines by a fellow flyer, he did something really bad with it, and it means to get it running I need to spend around $250 on it to get it right again. One of the things that needs replacing is the con-rod. I have stripped the engine down and noticed there is a stop screw on the big end, and I need to get it off. According to parts photo's it is a threaded screw so should be able to undo with a screwdriver, but it is a very narrow slit for a crew driver, and it is also a long slit. Anyone got any tips on how to remove this.
I see some people have had PCV' valves missing, others with the ball/spring installed incorrectly. Which way is it supposed to go. Assuming it needs to draw air INTO the engine, then the spring would go in first, then the ball, and then the nipple, is this right?
Regards,
Andy
I think the ball goes in first and then the spring.
