Thanks!
ORIGINAL: mr.rc-cam-RCU
To use the RC-CAM GP Patch on 900Mhz you would increase the dimensions of EVERYTHING by 2.66 times. This will get you into the ballpark, but it will not be fully optimized. However, the performance should still be good. Keep in mind that accuracy counts and that it is best to avoid using a coax cable (direct connect antenna to Rx).
