RE: Weedeater 25
Piper,
That is the stock carb. There is a noticable difference between the 18cc, 21cc and the 25cc engines.
The 25 has a beefed up crankcase, differant carb and carb block. The compression seems to be higher too. I didn't tweek the carb any on the initial test run and I was using regular gas. Perhaps there may be an increase if I use HI Octane gas?? What are your thoughts?
BB
