RE: Few Sig wonder ??
Thanks for the tips and nice wonders there!
the wing dowels and hold down will be beefed up and the tri stock sounds good on the tail. I just looked at the plans and book, seems a bit weak in that area. can you tell me why 85's over 81's? by spec they look to be about the same, do the 85's have a beefier gear train/motor? I was planing on using a 425 on ail, is the 85 really enough? after looking at the plans moving back the firewall to help with CG will be easy but dam there's already very little room for the tank, will a 4oz still fit? since I'm using a long pipe the muffler weight will be spread out along the fuse and not all right at the nose maybe i can get away with leaving the fire wall per plan. I already had the .25, it was a toss up between the Shrike and wonder to put it in. I really don't want another little motor laying around so i'll stick with the 25, it may be a hand full at first but what the hell.Ill set the CG and throws by the book, and i always seal my hinge lines.
thanks salmonbug
john
