RE: cv 12 mounted on lmh 117
Can I chime in?
Just a thought, with a metal feathering plate or CF plate which are available as aftermarket parts Also there is a distributor over in Germany selling Carbon fiber blades. Would these upgrades make that engine set up a little safer at the higher RPM head speed. It will take alot of force to rip through the fibers to sling(throw) a blade. Also i was thinking with the Longer blades and boom it should help in maintaining a lower RPM. Also A little more weight could be added to the chopper. I notice a big difference between the Electric and the gas versions weight and I also notice that the electric has and develops a higher head speed. I have both chassis and My electric version with the same blades and boom as the gas version takes off like a rocket and its a much heavier setup. help me out here.
