RE: What level of HAM is needed for 2.4Ghz Use??
I do not think that the video transmitters the you buy are in the Ham band on 2.4 anyway. So for that purpose you dont need a license, but you have to use them as they are and as intended and not modified as to power output or frequency, which is the same for the R/C frequencies on 72 mHz.
By the way the "ham band" at 2.4 gHz is 2.300 gHz (2300 mHz) to 2.450 gHz (2450 mHz, so actually only 50 mHz of the ham band is in 2.4 gHz.
