help mixing JR-8103
I have managed to set the mixing up so I can tie 2 channels together for my alerions. This works great. I then attempted to tie amy elevator to another aux channel (aux3). It works but I have the following problems:
1) The trim only work on the elevator channel and does not tie the aux in. (so only 1/2 of my elevator surface trims)
2) The aux 3 pot still functions and this could be troubld if I hit it by mistake.
My intent was to have seperate channels for these important surfaces. This way I do not have to rely on a "Y" connector and avoid a point of failure.
The manual is very little help. I made the elevator the master and the aux 3 the slave. No further information I could use. This is the same way I did the alerions and they worked...[img]i/expressions/face-icon-small-confused.gif[/img]
please help
thank
nick
