RE: Best Camera Position?
That's it exactly, Spanky!
The ZagNutz flies just a bit nose high and the camera is embedded in the right wing facing forward and if it's placed on level ground - it faces a little down. The servo is also embedded in the foam and it is on my channel 5, or landing geear servo so I only have an "up" and a "down". When I hit the switch, the camera pans straight down to the ground. Works OK for me. The left/right pan just doesn't seem like it's really required since the ZagNutz is so manuverable.
CTF
