3D "NOT SO" SLOW STICK
Thunder Poly 3s 2100mah
phoenix 10
naro std servos w/ GWS TX/RX
Himax 2015-4100 w/ GWS D Gearbox 12x8 gws prop
Mild mods I can think of off hand are copper tube to replace the stock aluminum tubing, 3 strips of clear packing tape across underwing for support, carbon string rudder/elevator support.
Have had good results withthis setup 1hr 15min + flight times. Can hover, ROG and climbs out of sight in about 20 seconds, light aerobatics, outside loops without effort, inverted flight, current setup pushes this bird to it's limits but makes for one hell of a $30 kit.
Looking for a good camera now for aerial vid and pics.
Good Luck
ORIGINAL: Billiam411
I just built the Slow Stick kit and I'm looking for a good setup. I've flown before.
What's your setup:
Number of cells: ________ What brand/mAh: ________
ESC model: ________
Servos: ________
Transmitter/Receiver: ________
Motor (stock or...): ________
Modifications: ________
Comments on flight characteristics: _________
- "I failed the quiz!"
Good luck!
