RE: GWS Slow Stick Survey
I used HS 55s Gws 5 amp esc 11 x 8 prop not sure what brand but 8 cell 720 mah stock 300 motor works great brass tubing for wing tube connections cause the aluminum rod cut in half and almose folded the wing. I probably get a 15 to 20 min flight. it flys awsome
