RE: Ever had a problem when swapping crystals?
There you go again "guessing"
Yes there is a problem ,you may have shot someone down .Like I said (A FEW TIMES) before . THE FCC DOESN"T REALLY CARE IF YOU SHOOT A TOY PLANE DOWN . But , the SPECTRUM module CANNOT transmit on the SHARED frequencies and cause INTERFERENCE with LICENSED industrial users . The mismarked crystal is only ONE actual cause of interference that a tech would have avoided ,try not to make your entire case on that one point. It waas only mentioned as ONE actual case.
The system is meant to eliminate as much harmful interference as is practical . If the system weren't working as it is we wouldn't be flying on these frequencies
Quote:
"What Spurtpilot and others tries so hard not to understand is that a mis marked crystal would be caught upon installation when the RESPONSIBLE tech checks the output frequency."
Of course the markings on the spectrum module are much better than the printed tape on some crystals. And you are still trying .
