RE: BTE Delta Vortex Construction Photos
some views
In my above post, I forgot to mention that the front main retract ply spar is doubled with a balsa spar, because the stock notch made for the fixed gear spar was too wide. You will see also that I had to make notches in the front plate of the nose unit to clear the engine mount screws
