RE: Receiver compatibility with RD 6000 TX?
I just looked at the manual for the RD6000. Page 24 describes how to alter the frequency shift. They use the term "PPM reverse" to implement negative shift.
Therefore, your RD6000 should work with your Futaba Rx's when programmed correctly.
Also, I forgot to answer your other question. You should never swap crystals from other manufacturers. Always use the same brand of crystal as the component you are placing it into. Sometimes it will seem to work, but it isn't worth the risk.
