RE: New HOW TO Posted: How to Install Robart Hinge Points
Zap Hinge Glue is designed for glueing Robart hinges. You do not have to baby sit it and it the hinges can be handled in about 30 minutes. Once it is dry, you cannot pull the hinge out. If you drill the holes for your hinges properly there is no benefit to using glue that foams. It just makes a mess and you have to baby sit it. If you did not drill the holes properly, you should use an appropriate size brass tube to drill out the area and glue in a balsa dowel and then start over. Although foaming glue may fill the hole, there is no substitute for a correctly drilled, tight fitting hole.
