RE: Scratch Built Ignition???
Hey guy's I'm pretty well convinced I'm going to use Jerry Howells TIM 6 kit and Modelectric PE coil on my Q35 with points to trigger it.This should work out fine for me cheap and reliable.I'm merely interested in shedding some weight.Does anyone know how to make a hub to take the place of the flywheel just to strengthen the area where the crank threads end in case of crash.I'm thinking of using a Ryobi flywheel as iI have several spares and the taper appears to be the same.Question is how to cut the center out? Thanks all help much appreciated.[&:]
