RE: Slow Stick Battery ... Lipo
I looked at the AXI and the Mini AC. Good advice Doc. I am leaning toward the Mini Ac 20 with the 6:1 Planetary Gearbox. Is that the one you were thinking about when you said 6.33:1 gear box? Is it close enough? I still plan to use my 3s1p 1500 Kokams. What speed controller that is compatible with LiPo LVC would you recommend?
Here is where my beginner status really shows up. What prop adapter do I need to use the 12x8HD you recommended
I have found 12x8 Slow Flier props for a 3mm shaft. I have heard of but not found 12x8 direct drive props for 4mm shaft.
One of the reasons I'm doing this hop up is fun = one bad mule slow stick. The other reason is to carry a Aiptek Camera and an extra servo to push the button.
Thanks for your help,
Doug
