Old 01-25-2004, 10:48 AM
  #46
matchlessaero
matchlessaero's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Half-A Profile Funfly
I am running a Norvel .061 with a tap in the muffler. Honestly, I don't think you will get the hovering performance from the engine without that tap. The pressure provided helps to keep a strong fuel flow when the airplane is in a nose-up attitude. Without the tap, I don't think the Norvel would draw enough to keep running well (leanout-sag-thunk).
Should be easy to get a muffer with the tap. My LHS's have them in stock, and Norvel has them here for 5.99 http://www.shopatron.com/product/pro...VL110156/100.0
Dru, as for covering, I did not shrink my Monokote down that tight. It vibrates like crazy in the air, but it isn't an issue. When I did it, I used my iron on a pretty low setting and worked slowly. This still does not take much time as it is a small airplane.
matchlessaero is offline
