RE: RE: Half-A Profile Funfly
What do you mean by a tape? Also, I am getting ready to start building so what do you reccomend on strarting, wing, fuse, tail. And how does the carbon arrow shaft work. do you glue the wing on and then slide the shaft thruogh it or what? Because if you built the fuse with it in in the start, you obviously could not get the wing on.
David
