RE: Running in below zero to 20 degrees...!
i run my savage every weekend in this cold weather. and haven't had an issue. no temp problems or starting or tuning issues. i just check the tune and set it for the cold. i'm kind of new to nitro motors but if the engine temps ok then there shouldn't be an issue correct? i can't see the cold affecting anything other than the tune which you can adjust for the conditions your running in .
