RE: Got a CEN MT2
As of yet, I have not heard of throttle servo problems or engine problems. I have however heard of problems with the transmitter. If you go back to Cen, talk to Sean. He is a great guy and should help you make sure you are getting the most out of your truck. Also, you said it was really hot and smoking a lot. How hot was it? that engine can run up to two eighty and still be in normal operating range. Oil and fuel coming out of the exhaust is also normal, that happens when you are breaking it in. You should not have richened the mixture unless you couldn't get it to idle. Also, the servo the hobby shop gave you sounds like it is the wrong servo for the job. and that is no fault of Cen. Cen will look at the truck, and they will give you an answer about what is wrong with it. I know this because of all of the help they have given me. If you don't believe me just go talk to sean about my truck. Good luck with it, and let me know how things go with your truck.
