RE: RE: RE: FOCUS II ARF construction by-the-numbers
Pro Pattern,
The candy colors are see through. If you were to spray a color behind them it would not be see through.
All the Pactra paints are to be sprayed on the inside of the lexan part.
The blue is Candy Blue. Not the The True Blue Pearl you have found at Tower Hobbies.
The window tint is what Eric H used.
Mike
