RE: Post photo of your WW-I model:
Hurri back again - Can I ask "Highflyer2" about his gorgeous Nieuport 28 ? I recently got a finished 28 from an estate sale , guy changed a lot of things on it . It hasn't flown .
I have got it together , but seems a lot of work at field to assemble it . Says I think on the info - leave the top & bottom left wings together attached to fuse with flying wires etc . Have the right wings together in a holding type jig & then put them on together at field . It is very difficult I find , have the bott; hatch off , connect the servo in middle , put the 2 pins that locate the wing lineup , 4 tabs with self tap screws , getting assembly over the cabane s , then all the outer cabanes screws & turnbuckles , lock wire ? There must be a proper way ? Any help ? thanks
