RE: RE: Duelist 2/40 progress photos.
To keep the wheels up for transporting, I use strips of velco with half a clothes pin in the nose well.
The fuse is the hardest part to build, (can you say, "PAIN IN THE BUTT"[:@]) as things are real flimsy and must be held in position to dry before proceeding. Again, I recommend a buddy to help here.[:'(] This is where you might want to decide where to mount the nose gear retrack and install the blind nuts. After you glue on the nose block, it's permanent. Not in the plans.
