Here's what I put together. Get's pretty good results from my inexpensive setup.
Nice set up will try something similar, thanks for the idea! I now have to find a cheap enough cam corder do you have any suggestions?
you should remove the rx antenna while you tune it in to the tx. This eliminates those evil ghost signals you can pick up. Replace the rx antenna after you have it tuned.
Tried that and works well once again thanks for your tips
What does y2bnormal mean by ready to fly systems?
