What will your imac planes look like in the future??
Just thought this would be an interesting discussion topic. What is the next generation of unlimited acrobats look and fly like after the current used monoplanes, will they follow rc trends with extreme power to weight? will they stay with the conventional monoplanes??
The next Generation
You are on the runway at air show center, engines idling. When the cue comes, you take a deep breath and advance the throttles to full power. Instantly you are thrown forward at some 1.4 Gs, straight down the centerline.
Within three seconds you are airborne, accelerating rapidly as you rotate into a vertical climb. You ease back on the throttles and listen for the variometer indicating zero climb at about 200 feet. With airspeed pegged at zero you nimbly roll to the left, feed in some rudder, and translate horizontally back down the runway. Directly over your takeoff point you bring the airplane to a stop and wave to the crowd. A “curtsy” with a wag of your tail signals the beginning of your performance.
http://www.visionpacific.com/humming...mePage2_F.html
