Day One - Wing Assembly
The wing is a two piece fit with a fairly heavy wing tube. The tube slides into the phenolic receivers snugly, but not too tight. The dihedral is pre set and the rear alignment dowl fits perfectly. The wing fits perfectly in the saddle.
Once you slide the wing halves together, you just bolt the wing in place with two hold down bolts, just like any 40 sized plane, neat!
