RE: landing gear for the Sky Scooter Pro 2?
I had the exact same problem with my SSII... where I slamed streight into the ground from about 20 feet, the nose broke off and then I didnt have much power anymore. What had happened was one of the motor wires had broken half off so my motor wasnt getting its full current and I had about half the power I had before the crash (not even enough to keep it in the air). The only thing needed to fix it was to solder the full wire back on to the motor. I'm wondering if this is the same problem you had. Might be worth it to check the wires. Good luck!
