RCU Forums - View Single Post - Magnum problems
Thread: Magnum problems
Old 06-13-2002, 04:53 PM
MMallory
Default Magnum problems
Evan,
If you have that many problems you might want to sent it back for an exchange. Mine didn't need any more heat shrinking than any other ARF. If I remember, my instructions didn't specify a CG so I called JD and got it from them. I can measure for you when I get home. I didn't notice down thrust. I just mounted the engine and went flying. So far, the weird elevator set-up is working fine. Launch is actually a little more stable than the dust.
One problem I did have was the tank split. I know that's what I deserve for using the ARF pre-packaged stuff. No damage to date from belly landings on grass (no extra protection). Added Q500 gear to make this a one man operation.
Mark M.
