RE: Carbon Fiber Booms
CA usually works very well. Fast epoxies (5-min, etc) usually just peel off. The 30-minute might be ok. I use regular laminating epoxy resin. Whatever you use, make sure you scuff the surfaces with sandpaper and clean away any residues with acetone.
-David
