JR 10X Mixing Question
Greetings,
I am setting up a BV Saber. I have the brake valve mounted such that the retract servo can activate it when the servo drives forward slightly more when the gear is in the down
position (pretty typical set-up). The problem I am having is I want to activate the brakes via the slider on the RIGHT side of the transmitter (AUX 3), but I can only get the slider to effect the servo when the gear switch is in the UP,or toggled toward you, position. I need to have the mix occur when the switch is gear down, or in the position away from you.
I cannot seem to get this to work..Any ideas?
Regards,
Kevin Barr
