Throttle Mixing
Ive got a twin engine plane and I cant get the motors to run exact. I cant adjust the carby links either because they are in the cowl which is glued down. Ive got the new JR 6-channel X2610 transmitter and I was wondering if you can mix the two throttle servos together using another channel? I want to be able to individual idjust each engine from the transmitter. Or is there anyway of doing it at all. Any help would be good
Rossco
