RE: Antenna concerns for Transmitter
if you broke the solid end section you can simply replace it with an identical length of wire....nothing mysterious about the workings of the antenna, it's simply a conductor of a certain length. for years i've been using a solid whip of the same length as the original collapsible antenna. i think it's better because it never breaks and it will never loose continuity like a sectioned antenna will when it starts wearing out.
dave
