RE: 6102 weird stuff happening
Hmm I think you've got it! Also I am putting together a Venture 30 with this radio. I'll look into the failsafe default. Yes I have 1 flight on the plane that's doing it. I almost crashed on the maiden because I didn't do the smart thing and properly range check it. Dumb and dumber working here. I had the antenna in the fuse and it's not good enough. While flying I think I had a weak signal and the throttle was constantly bumping into full. I'll get these items worked out. I have used the Transmitter on 2 other electric planes flawlessly so I have confidence with the rig. Thanks, Mike
