I would recommend that you use the point mix instead of a linear mix. The point mix will allow little to no elevator until you reach the half way point then add mix during the remainder of the elevator travel.
ORIGINAL: David_Moen
Howdy all.
Dumb question coming....
I have a Vector Flight 66" Extra that pulls to the belly when flying knife-edge. I've heard about programming this out using the TX, but I want to know more about it before I give it a try. I have a Futaba 9C.
I assume that I would program the TX so that some up elevator gets dialed in with rudder input. Is it usually a proportional mix? More rudder = more elevator?
I assume that this would be a mix that I turn on prior to making a KE pass, then turn it off when I'm done right?
What are the steps required to program this type of mix?
Thanks for your input!
