ORIGINAL: yrral
that might be it. but the only thing is, that would keep the truck from moving, if it isn't working right?
It might not move. In my case it was tight enough to move the truck along, just wouldn't let the rpm's build up enough to shift the tranny. The motor was producing the rpm's, the slipper clutch was slipping at the peak of the load and not letting the tranny shift.
I don't know if that makes any since, but if you tighten it up and it doesn't help then it's something else. just sounds similar to what I had.
