RE: tmaxx not shifting, gunna throw away...
mine was doing the opisit. it was shifting as soon as it started moving so i took that little rubber thing of looked for the allen thats in there and tightened it and it fixed it. it shifs right at thr right time, with no problems exept that now it some times stays in 2nd gear. if i go then let of the gas then let the engine slow it down it then kicks into first but if i use the brake it stays in 2nd. so i thought maybe my bearing for my clutch are bad. would that make it not shift back into 1st.
also if your going to through it away could you give me some parts off of it. i would pay for them of coures
