ORIGINAL: dbl8ts
Dear A10Flyr:
Thanks for the clarification. Are you still using the Jeti with the EDF 55 set-up, or did you change to another controller? I noticed in some fall posts you exchanged with the guys at E-Flight that they were using two separate controllers in addition to some other expensive equipment.
That wasn't me on e-flight. I used a Castle Creations controler
Woody 51's comments to Clausxpf make good sense, and I agree with him 100% when it comes to the A-10 investment.
Now that I have a good idea about what battery to use, I will now concentrate on the controller and how to wire the engines. (Is your wiring the same as the stock method or did you have to get creative?)
Yes my wireing IS stock.
Again, I thank you for your posts. I have derived a lot of information from your trials and errors and look forward to any more information you can share. I'd say you know a whole lot about electrics. Each step you took after frying the 50s was logical and yielded success. By the way, no dummies here, just modelers doing what modelers do - trying to get um airborne and keep um there.
Thanks. Don't forget the bamboo skewers! They work!
dbl8ts
