Servo Problem?
Danny,
I was flying my old Cloud Dancer .60 a few days ago (for the first time in a while) and started having problems. I would be in level flight and it would bank 90 degrees into knifedge. It banked 90 degrees to the right every time. The ailerons were the only surface that was acting up. It continued with the "fits" coming closer and closer together. I finally crashed the plane as the last time it did it I was too close to the ground. I was flying with an 8103 tx and 549 rx. I sent the rx in and they said it was OK. The battery was fully charged, could this have been a servo causing the problem? The servos are 517's. The tx is used on several other planes and I have had no problems so I don't think there is anything wrong with it.
Thanks in advance,
Alan
