RE: xp 6102 Throttle to Throttle Mix
I'm not seeing anything in the manual re: a throttle to throttle mix, however it does show a "screen shot" which shows a throttle to throttle mix. This is just the default setting without changing anything of the mix, showing where all the options that can be changed are. What type of mix are you wanting to set up?
