RE: Futaba 9zap W2 range check
Thanks Guys,
I will do some more tests tomorrow. I usually test with the model on the ground which makes things a bit worse.
I did walk more than 1000 feet with the antenna fully extended with no servo stuttering. I will do another test with the antenna up one section and make this my baseline.
By the way my old 9VAP using the same module and RX has an antenna fully down range more than double the 9ZAP.
The model has a 48cc gas twin. So I can then see if the ignition has any effect.
Thanks again for all your input.
Regards
