RE: No trim offset in function mode! Why?
I assume you have the digital trim version of the 8103? If so, trim offset is not a function available, as it is not needed with a digital trim system. Trim offset stores the trims of a model so that the trims can be centered so that each model memory, they will be centered. With a digital trim system, the trims are automatically stored for each model, negating the purpose of a trim offset function.
