ORIGINAL: hilleyja
QUESTIONS:
3) Based on NOTE4 and NOTE5 above, could any faulty Hitec HS-56xx servo cause this convulsive interference problem with ALL of the control signals?
Jim, you hit the point but is not a faulty servo, is a faulty design servo, i don't know if the interference is in the control cable or in the power cable but is there if the voltage is over 6.2v and all other good servo connected to the system will glitch also
The only fix i found is using a good large 4.8v Battery like a 2200Mha SR Batteries but watch your voltage between flights and don't let the voltage drop below 5.3V because that servos also stop working with low voltage or long extensions, with that battery my setup worked but i don't feel enough safe with servos who stop working with half battery charge and replaced it with 5945, now all work fine on 4.8 or 6 volts
I know other have found same problem check here for more info
http://www.rcuniverse.com/forum/m_20.../tm.htm#202189
http://www.rcuniverse.com/forum/m_11...tm.htm#1156895
http://www.rcuniverse.com/forum/m_16...tm.htm#1693762
http://www.rcuniverse.com/forum/m_16...tm.htm#1667977
