RE: Field charging my XP6102?
Yes, JR is different polarity in the charge plug than other brands, JR is center pin negative. I'm not sure on the hobbico part, likely that is what they have done, but I can not say for certain, you would need to ask them to know for sure. With a banana jack set up, you can likely plug the red into the black and vice versa to get the polarity is correct, but verify this is correct before charging.
