RE: What kind of servos should I get for my CEN
Before you mess with the idle, set your throttle trim to center with the engine off. Then pull the servo horn off and move it so that the carb is closed or most of the way closed, re install the servo horn. Then re adjust your brake so that it is full engaged when the brake is fully depressed. Then if this doesnt completely fix your idle problem, retune the engine.
