RE: Does lead tail weights affect RX reception?
Most folks with modern Quickees do just as you are doing and even dispense with the weight of the tube and this is running along the Carbon fiber pushrods. It works fine. Are your two tail surface survos mounted behind the wing trailing edge?
John
