RE: Range problem w/50MHz
That doesn't sound normal at all, the range should be better, and you are doing the range test properly with the antenna out of the 10X. It sounds like there may be some noise in your area on those channels, but this is only a guess. Feel free to send your equipment in for a check up to find out for sure.
